楼主 发表于:2023-02-13 12:06:03
77国产品牌滤芯均为我司生产的替代原厂品牌滤芯,其过滤滤材采用德国原装进叢/span>HV公司产品,注册商标为“佳洁”牌。本公司涉及的其它品牌均无品牌意义,只是作为产品型号参照和客户选型对照使用。进口滤芯和过滤器为原装进口,有防伪标志。我司长期为国内各大企业贴牌生产各种款式的压缩空气精密过滤器滤芯、/span>
适用介质9/span>空气
适用范围9/span>石油,化工,电力,钢铁,船舶,喷涂,液压机械,汽车等行业
使用寿命9/span> 8000小时
规格尺寸:齐?/span>
产品描述9/span>
滤芯概念:利用吸附式、凝聚式等过滤原理除去空气中的油、水等杂质的过滤设备材料,用于过滤器中、/span>
主要构成:滤纸、骨架、海绵等
广州东誉滤芯+/span>以下为相关型号:
DF0009'/span>G(/span>-AO?/span>DF0009'/span>G(/span>-AA?/span>DF0009'/span>G(/span>-AX?/span>DF0009'/span>G(/span>-ACS?/span>DF0009'/span>G(/span>-AR?/span>DF0009'/span>G(/span>-AAR:/span>
DF0018'/span>G(/span>-AO?/span>DF0018'/span>G(/span>-AA?/span>DF0018'/span>G(/span>-AX?/span>DF0018'/span>G(/span>-ACS?/span>DF0018'/span>G(/span>-AR?/span>DF0018'/span>G(/span>-AAR:/span>
DF0028'/span>G(/span>-AO?/span>DF0028'/span>G(/span>-AA?/span>DF0028'/span>G(/span>-AX?/span>DF0028'/span>G(/span>-ACS?/span>DF0028'/span>G(/span>-AR?/span>DF0028'/span>G(/span>-AAR:/span>
DF0038'/span>G(/span>-AO?/span>DF0038'/span>G(/span>-AA?/span>DF0038'/span>G(/span>-AX?/span>DF0038'/span>G(/span>-ACS?/span>DF0038'/span>G(/span>-AR?/span>DF0038'/span>G(/span>-AAR:/span>
DF0058'/span>G(/span>-AO?/span>DF0058'/span>G(/span>-AA?/span>DF0058'/span>G(/span>-AX?/span>DF0058'/span>G(/span>-ACS?/span>DF0058'/span>G(/span>-AR?/span>DF0058'/span>G(/span>-AAR:/span>
DF**8'/span>G(/span>-AO?/span>DF**8'/span>G(/span>-AA?/span>DF**8'/span>G(/span>-AX?/span>DF**8'/span>G(/span>-ACS?/span>DF**8'/span>G(/span>-AR?/span>DF**8'/span>G(/span>-AAR:/span>
DF0088'/span>G(/span>-AO?/span>DF0088'/span>G(/span>-AA?/span>DF0088'/span>G(/span>-AX?/span>DF0088'/span>G(/span>-ACS?/span>DF0088'/span>G(/span>-AR?/span>DF0088'/span>G(/span>-AAR:/span>
DF0102'/span>G(/span>-AO?/span>DF0102'/span>G(/span>-AA?/span>DF0102'/span>G(/span>-AX?/span>DF0102'/span>G(/span>-ACS?/span>DF0102'/span>G(/span>-AR?/span>DF0102'/span>G(/span>-AAR:/span>DF0142'/span>G(/span>-AO?/span>DF0142'/span>G(/span>-AA?/span>DF0142'/span>G(/span>-AX?/span>DF0142'/span>G(/span>-ACS?/span>DF0142'/span>G(/span>-AR?/span>DF0142'/span>G(/span>-AAR:/span>DF0180'/span>F(/span>-AO?/span>DF0180'/span>F(/span>-AA?/span>DF0180'/span>F(/span>-AX?/span>DF0180'/span>F(/span>-ACS?/span>DF0180'/span>F(/span>-AR?/span>DF0180'/span>F(/span>-AAR:/span>DF0220'/span>F(/span>-AO?/span>DF0220'/span>F(/span>-AA?/span>DF0220'/span>F(/span>-AX?/span>DF0220'/span>F(/span>-ACS?/span>DF0220'/span>F(/span>-AR?/span>DF0220'/span>F(/span>-AAR:/span>DF0280'/span>F(/span>-AO?/span>DF0280'/span>F(/span>-AA?/span>DF0280'/span>F(/span>-AX?/span>DF0280'/span>F(/span>-ACS?/span>DF0280'/span>F(/span>-AR?/span>DF0280'/span>F(/span>-AAR:/span>DF0360'/span>F(/span>-AO?/span>DF0360'/span>F(/span>-AA?/span>DF0360'/span>F(/span>-AX?/span>DF0360'/span>F(/span>-ACS?/span>DF0360'/span>F(/span>-AR?/span>DF0360'/span>F(/span>-AAR:/span>DF0428'/span>G(/span>-AO?/span>DF0428'/span>G(/span>-AA?/span>DF0428'/span>G(/span>-AX?/span>DF0428'/span>G(/span>
